How to loosen battery screws?
I just had to fix a flea power problem. The solution said to remove the battery. fortunately, that wasn't necessary because the 3 larger screws are cemented in. Well, maybe just Loctite, but I cannot break them loose. What they screw down is the plastic battery frame, so how do I break them loose? Obviously, heat may melt the frame.
Is dit een goede vraag?
