Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
MacBook optical drive in iBook
Can I replace iBook G4's optical drive with one from MacBook (A1181)?
Is dit een goede vraag?
Commentaar:
If one of these answers fixed your problem please hit the "accept" in list that has "History Edit Flag Accept Comment" located to the upper right of your question so we can remove it form the unanswered list.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
MacBook drives use the same PATA interface until the Early/Mid 2009 models.
Regardless, iBooks use a full-sized drive, and the MacBooks use slimline drives, so they are not compatible. Sorry!
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
They're definitely not inter- changeable. The iBook uses Pata connector and the A1181 uses a sata interface.
Score 3
Commentaar:
Are you thinking of hard drives? The A1181 uses the same interface until Early 2009 models.
door
You're right Ben, good eye!!! I was thinking hard drives. Thanks for the pull_up!!
door
As you can see here, I don't believe that the drives are interchangeable.
Score 1
Voeg je antwoord toe
teeeveee zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,096
