Loose connection in LCD, gives a color line in the middle?
As my topic describes, I have a colored vertical line on my display.
It is not permanent, however, if I press my thumb against the "spot", and use my other fingers to press the left side against myself, it works perfectly fine.
When I turn the lid up and down, eventually, it will work.
I have linked a before and after scenario. It's not a GPU problem, since I easily can use an extern monitor.
When I start my MB: http://gratisupload.dk/vis_billede/66929...
When I've "fixed" it: http://gratisupload.dk/vis_billede/66929...
It must be some kind of "loose connection" in my monitor, but is there anyone who knows how to fix this problem, other than buying a new?
This happened after I dropped it on the floor, so that is why I'm guessing that it's a loose connection.
Is dit een goede vraag?
1 Opmerking
Am I not expressing myself clear enough?
door Rune Ref
