Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
Vraag afgerond
iPhone keeps rebooting after replacing battery
After replacing my 3gs battery the phone keeps rebooting every few minnuts, I replaced the old battery and the phone works fine, after serthing for the solution,
it apers to be one of three things,
1) a defetive battery.
2) the rong battery.
3) compatibilety issue between te latest OS and non OEM batterys "OEM batterys aperintley have an ID chip that the OS looks for"
The old battery is APN:616-0431 VPN:GB-S10-374270-0100
The New battery is APN:616-0435 VPN:LIS1416APPC.
can eney one tell if I have the right replacment battery or not?
Is dit een goede vraag?
4 opmerkingen
It can be hit and miss with 3GS battery replacement. Buy another from another vendor. That apn should be fine but... Read feedback before buying off eBay etc
door
You Have the right one, probably just a bad battery.
door
I have exactly the same problem!! replaced the battery in my old 3G and the thing keeps rebooting.
door
I have the same problem.
I have same APNs and VPNs as you. Please post your solution if you have found any.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
just receved an email from Ifixit they think its a bad battery and there sending me a new one. thanks to Ifixit and every one here fore the help.
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 3,037
