Battery Not Charging, Only 1.2V at Terminals
What could cause an Ipod Touch 2G to only have 1.2v across the battery terminal when plugged into USB? I replaced the battery with a known good one and the issue remains. When I remove the ipod from the USB cable, the voltage drops to 0.25v.
I dont know if it could be the charing port or the Power Management IC?
Thanks!
Is dit een goede vraag?
2 opmerkingen
I left it plugged into an AC adapter for a few hours and the results are the same. Not sure what else to check. I think something may be shorted out...??
door AnthonyM84
Check your dock connector and see what you get. Checked the connector to make sure the pins are okay? Also, your battery is a new one or used one? I'd go with the easy stuff first.
door oldturkey03
