Ga door naar hoofdinhoud
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
368 Vragen Bekijk alle
27'' iMac 2010 Backlight Failure
The backlight on my 27’’ iMac 2010 is slowly dying. Getting a little more dim every week, and I can see dark spots between the backlight “bulbs(?). I don’t have the tools or the skills to do the soldiering like some people recommend. Should I try to replace the display or does the inverter board solve this issue? How can I tell if it’s the inverter board or the literal backlight strip?
Also does a 2011 display work in a 2010 machine?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Most likely the LED bar connection or a few LED have died and often the backside also gets darkened
Here’s one source iMac 27" A1312 - Mid 2010, Apple P/N 661-5568 and the guide iMac Intel 27" EMC 2390 Display Replacement
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks so much, Dan. Wish the news was better, but I appreciate your expertise. Would a 2011 display work in a 2010? I ask because I found a cheap one in my area.
door
@daevrojn - There are some differences. It will take some work to convert it.
door
Voeg je antwoord toe
Alex Nevin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 33
Altijd: 235
