Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Model No. A1367 / 8, 16, 32, or 64 GB capacity
1321 Vragen Bekijk alle
sleep/wake button is loose and wont work, need help!
okay, so I have this ipod 4 and I havent tried to fix anything yet but so far only the sleep/wake button wont work... its loose and it wont work. can someone tell me whats wrong and maybe tell me how to fix it?? youtube and apple havent done me much good... thank you!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Niko,
First off how long have you had it? I would try taking it to Apple regardless. I know several people that took in broken screens etc. that were out of warranty and the Apple store replaced them no problem!
If not you need to carefully disassemble it. In order to fix it you have to take it all the way apart which usually means you will have to replace the front panel assy. Follow the teardown guide here:
iPod Touch 4th Generation Teardown
Step 23 shows the button top right. there are 2 screws holding it in place and secured with blue loctite thread sealant. See if these are loose and get them tight. If they are not you have a different problem.
Was dit antwoord nuttig?
Voeg je antwoord toe
niko1234110 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,313
