Ga door naar hoofdinhoud
Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
330 Vragen Bekijk alle
Installed new SSD, can't update to newer macOS
I managed to install a new SSD into my 27” iMac and was able to perform an internet recovery and everything. However, my issue now is that I can’t install a newer OS from the downloads I get off of the Apple website. The error “this download is damaged, you should put it in the trash” keeps coming up.
From some research I’ve done it seems this could be due to expired certificates. I’ve attempted the fix I’ve read where you disconnect from the internet and use Terminal to change the date manually, but the computer still displays the same error when I use that to change the date to Jan 1, 2015.
The computer is running Mountain Lion and I was attempting to install either Yosemite or High Sierra, but the issue occurred for both. Any way to correct this?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
The highest your system can run is Catalina (10.15.7) make sure you are only going that high.
I would recommend you download the file directly from Apples site following this guide How to get old versions of macOS Some browsers don’t handle things correctly from Apples site so make sure you are using Safari. Then follow this guide to create a bootable OS installer USB thumb drive How to create a bootable installer for macOS
Was dit antwoord nuttig?
Voeg je antwoord toe
Cruxx zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 107
