Ga door naar hoofdinhoud
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
203 Vragen Bekijk alle
Why won’t my system read cartridges
Every time I try and play a cartridge game, it never works I also hear this grinding sound, I have no idea why this is happening, can someone please help
Is dit een goede vraag?
Score 1
2 opmerkingen
it makes the grinding when on and sitting on a flat surface?
there are no real moving parts in the console so it seems like the grinding would be coming from the speakers probably.
door
No, it’s when I put a cartridge in on any surface
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
You can try replacing the cartridge slot. The grinding might be coming from thing on the pins or in the slot itself.
Was dit antwoord nuttig?
Score 1
Before replacing the slot, you could try a trick to clean the card reader pins first.
  • get some isopropyl alcohol and thoroughly soak the contact points of any cartridge with a Q-tip.
  • put the cartridge in the slot and insert/eject the cartridge repeatedly for about 3 minutes.
  • try it again and see if that fixed it.
hope this helps!
Score 1
Voeg je antwoord toe
John Bitzas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 193
