Time Capsule Won't Power on, PS seems good
I swapped power supplies with an AirPort Extreme and it worked in the Extreme, so I’m thinking a board issue.
Any leads here?
Is dit een goede vraag?
Any leads here?
Not good ;-{
You could try disconnecting the drive to see if that is clamping the power (shorted out), otherwise you have a logic board issue which will be hard to diagnose as there are no publicly available schematics or board views to reference.
Was dit antwoord nuttig?
Triple check all the flex cables - either you may have not connected them well enough or some of them may have torn accidentally - if possible check their continuity with a multimeter and some really thin probes.
P.S.: I’d even start with checking if the power socket wires are soldered as they should after reassembly and if they are still continuous - if not this could be an easy fix
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 90
Is the LED lit?
door Dan
@danj nope, no signs of life
door Jon
