Ga door naar hoofdinhoud
Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
247 Vragen Bekijk alle
To all the GBA Reballrepair neuro surgeons... expert question
My Macbook 1707 PMIC got hot. Removed the chip and the fifth pad from the bottom left (PP5V_S4) was carbonized (also the exact trace to this pad is not obvious). After carefully scraping the pad to expose some copper it shows a 0.3 ohm short.
I know this is a complex issue but what is the best way to deal with this?
Assuming ground is the top layer surrounding each pad, is the right way to deal with this to scrape away the ground top layer around this pad? If it's not the best way to deal with this, what do you recommend ?
Thanks for your guidance.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Dealing with missing pads depends on what IC they are under and the position of the pad. It is not easy finding a trace under a buck converter as sometimes you have to scrape down a few layers to find it and you risk severing other traces on different lines if you scrape down to many layers.
In your situation I would put some UV mask on the pad and just run a jumper from the closest PP5V_S4 component, it’s a no-brainer if the pad is on the outside.
Was dit antwoord nuttig?
Score 3
7 opmerkingen:
Thanks Chris. As you can see on the picture it's on the outside (fifth pad from the bottom left) but I am afraid this very pad is shorted as I have .3 ohms on this pad.
Couple of questions:
1) Is it fair to assume that if the trace on which I'd put solder mask on is shorted, then the short will remain so I don't understand how this would work.
2) If the original V5S4 pad under the PMIC feeds V5S4 to many other places, wouldn't I'd lose all these other connections if I bypass the original trace?
Just trying to understand your proposed fix. thanks for the help.
door
Dan I don't have a microscope camera yet. That's the best picture I can take with my iphone through the microscope.
door
@jmd1010 - You didn't get in imbedded yet! You got it to the image toolbox but its not visible until you past the image link into your question.
door
@jmd1010 Oh my, there has been a lot of heat put on this board. Are you sure your multimeter isn’t on diode mode? If it is this value would be acceptable. If not you need to test another component on that line to rule out your probe isn’t touching ground at the pad.
Once you have determined you actually have a short you need to find the shorted component. Once you have replaced the component you can run a jumper to the missing pad.
I would first clean all the reflowed solder around the area so there is nothing bridging.
door
2 commentaren meer tonen
We really don’t get this deep as most people here are more focused on assembly level replacement for the repair.
You really need to get your hands on the schematics and board views for your system. Do a search for 820-00928 which is the board number, you should be able to find someone who found them after falling off the back of the truck ;-}
You should jump over to Louis Rossmann’s site Louis Rossmann - 15” MacBook Pro - 1707 repairs
Score 1
5 opmerkingen:
Hi Dan, I have both the schematic and boardview but they are of no use to address this problem. Hope someone with experience in component level repair could provide guidance.
door
@jmd1010 - Good! You should be able to ID the signal the pad offered/needs. Even still you need to figure out what was the cause of the issue. Did you have liquid damage, another part messed up so this is a cascaded reaction.
Maybe Chris @imicrosoldering can help you but he will need a good tight picture of the damaged area as well as another zoomed out image so he has a reference of the board layout position. Voeg afbeeldingen toe aan een bestaande vraag
door
No water damage. It is a case of a faulty charger.
door
@jmd1010 - Did you have liquid damage, another part messed up so this is a cascaded reaction.
9 hours ago by Dan
door
@jmd1010 - Ah, sorry ;-{ Didn't get the linkage.
door
Voeg je antwoord toe
jmd1010 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 87
