Ga door naar hoofdinhoud
Flagship smartphone from Huawei released April 2018. Model CLT-L29.
49 Vragen Bekijk alle
My phone just stoped working. I have a complete black screen.
So black screen, charging doesn't work I don't even get the red light. Plus when on put it on charge (original charger) the only thing that happened it the screen will blink on and off the Huawei logo. I tried the reset ( touching 2 buttons same time) but that doesn't work.
Anyone have any ideas?
Thanks for your help
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
When did this problem start did you just have something replaced on the phone or did you do an update on the software? If you have done any of these things then it's most likely a software issue and you will need to have the software reinstalled. If you have not done any of the above then the problem is with the screen itself especially need to check the connector plug on the main board if not the plug then it is the actual screen that is damaged and will need to be replaced. Please post update as to whether your issue was resolved.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Julie Gregoire zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 29
Altijd: 126
