iPhone 8 plus only works with original display
I have a very broken display. Only lines show up. I have now tried three different replacement displays and they are fully black. Nothing works. No hard reset nothing.
When I put the original display back on and do a hard reset it still shows the lines and lights come on.
I haven’t transferred true tone data, that is the only difference. I don’t have a prommer for that.
Is dit een goede vraag?
5 opmerkingen
Further info. I can hard reset device into finder and do update/restore. But unable to find a working display for it. Connector pins look normal in all displays including the original and connectors are intact. I will do an update to the device and then see if nothing changes. Maybe mext move is to start reseating connectors 0,1 mm to another direction and see if there is a position where the display happens to work.
door teemupa
Have you tried using another OEM display, or just aftermarket displays?
door Andrew S
Just aftermarket. I put the last display that didn’t work into another phone (7+) and it worked normally.
door teemupa
@teemupa There are two options I see for further troubleshooting: buy the JC V1S($130) to reprogram an aftermarket display(the JC V1S can also reprogram batteries) or get a used or broken iPhone 8 Plus with a working display ($72).
door Andrew S
I guess I will search for a display then. This is a first.
door teemupa
