short battery run time
On my 3rd replacement battery. Have followed all the calibration guidelines, but initial battery run-time was only 2 hours. Is this normal for a new replacement ? Is there something I can do to increase the run time ? Thanks for your attention. This is the CocoBatt view after first discharge phase of calibration of new battery
The is CocoBatt after discharge and full re-charge. Took 2 1/2 hours to full discharge.
Is dit een goede vraag?
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Voeg afbeeldingen toe aan een bestaande vraag
door Dan
mind telling us why did you change your battery 3 times?
door Lock
@danj
see pix of early calibration phase of NEW REPLACEMENT BATTERY.
door stevesamrob
@lockxh
First battery began to swell and press up against track pad, causing erratic trackpad behavior. Second battery retained charge for only about 1 1/2 hours and would only charge up to about 50% of design capacity. Both had been thru calibration sequence.
door stevesamrob
