Ga door naar hoofdinhoud
Repair guides and support for tablets manufactured by Polaroid.
L 10 is the model not turning on
L 10 polariod wont power on were can i find repair guide
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Ok like @oldturkey03 said it's probably battery and if lithium is drained below 2.7v most systems will not attempt to charge it. Sometime you can successfully being it back to life with a 18650 battery. Only have it connected in small quick burst while the unit is unplugged. They will heat up pretty fast so 5 seconds bursts. Then let it cool. Soon as you get it to >=2.8v remove 18650 and try charging normally.
If not keeping or taking any charge at all than take a picture of the battery pack & I'll find you a link for a replacement
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
celo johnson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 142
