Ga door naar hoofdinhoud
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
772 Vragen Bekijk alle
Mid 2015 15” retina into a 2014 15”?
I have a dead 2015 15 inch retina MacBook Pro. The display is fine. The display has the same video connector as well as iSight camera connector etc. All the cables match up perfectly on my one year older 2014 Retina 15 inch but when I powered on I’m not getting any kind of image on the 2014. Is this display not compatible with the 2014 inch model that’s only one year older? Again all the cables fit perfectly and fits just like the original so I’m assuming that it must not be possible even though the cables fit securely and are of the same pin count etc. and plug right in. Can anyone shed any light on this for me please?
Is dit een goede vraag?
3 opmerkingen:
I have some zip cord which I use for my speakers which are too short to reach my stereo in my new room, if I happen to put on a AC plug on cords so I can use some AC extension cords to extend the lines to my stereo I better not mess up plugging the extension into the AC outlet! Otherwise the speakers will have a smoking hot time!
One can't assume a given connector is wired (defined) the same which is the case here.
door
That was just a weird analogy lol
door
@faslane - Need a little bit of fun ;-}
Sadly, a friend of mine back in collage days did this and his roomy gave it a try!
door
Voeg een opmerking toe
1 Antwoord
Sorry Apple messed you up! They changed things.
You must use the MacBook Pro 15" Retina (Mid 2015) Display Assembly display for your Mid 2015 system the 2014 display is not compatible!
MacBook Pro 15" Retina (Mid 2015) Display Assembly Afbeelding
Product
$519.99
Was dit antwoord nuttig?
2 opmerkingen:
Actually I’m asking the opposite. The 2015 logic board is done so I was hoping To use the display on my mid 2014 from the mid 2015
door
@faslane - Same deal ;-{ The 2015 display won't work in the 2014 system either.
MacBook Pro 15" Retina (Late 2013-Mid 2014) Display Assembly
door
Voeg je antwoord toe
Faslane zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 213
