Ga door naar hoofdinhoud
Apple's top-of-the-line smartphone for 2020. Announced on October 13th and released November 13th, the iPhone 12 Pro Max sports a 6.7" OLED display, a triple rear camera system with LiDAR, and 5G connectivity. Successor to the iPhone 11 Pro Max.
105 Vragen Bekijk alle
Rear camera lense iPhone 12 Pro Max
The telephoto camera (bottom left) glass that covers the actual lense is cracked exposing the lense of the camera. What component do I need to change to repair it?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
To replace cracked lens glass, use iFixit's replacement rear camera lenses and bezels in addition to replacement adhesive.
iPhone 12 Pro Max Rear Camera Lenses and Bezels Afbeelding
Product
$12.99
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Which bezel goes with which iPhone lens? The product comes with three different size bezels.
door
You can buy replacement glass on eBay etc, usually come as a set of three. Make sure they come with the adhesive rings. You have two choices.
Remove the damaged glass from the outside using a sharp blade to pick the glass out and risk damaging the camera lens itself or open the phone, remove the camera module and push the glass out from inside.
A shop would charge maybe 25 pounds to do it.
Score 1
Voeg je antwoord toe
Gil Zigelstein zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 582
