Ga door naar hoofdinhoud
Sharp TV led 40" Ultra HD
1 Vragen Bekijk alle
Black stripe on my Sharp Aquos Tv screen
Yesterday I had to remove the back lid of the screen to Unplug the Power cable from the inside. After putting all the pieces back together (screws and lid)I noticed that a black vertical stripe roughly 3cm large has appeared on the right-hand side section of the screen. Today I opened the posterior lid one more time to check whether the connections were fine and they appear to be properly plugged in without any damage. Does anyone have any idea of what the cause could be and if there is a solution to the problem???
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
The screen was impacted, bent, smashed, damaged some how, or a capacitor is going bad, some times they swell up before they blow out, they at times may leak as well, a visual inspection may reveal this condition, it looks damaged by your picture though. if under warranty turn it in or get the extended warranty asap?
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
lorenzo sponzilli zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 341
