Ga door naar hoofdinhoud
Apple's top-of-the-line smartphone for 2020. Announced on October 13th and released November 13th, the iPhone 12 Pro Max sports a 6.7" OLED display, a triple rear camera system with LiDAR, and 5G connectivity. Successor to the iPhone 11 Pro Max.
97 Vragen Bekijk alle
How do I replace the camera lens bezels?
The long and short is that I ran my phone over with my bike. Had I had a slighty more durable case, everything would be fine. The phone is otherwise flawless - a testament actually to the durability of the phone (something I thought I’d never say…).
In any case, I see there are the lens replacements (with bezel) available from the store (see link). However, there are no guides to actually do this procedure. Is it worth my time or should I just install a new lens?
iPhone 12 Pro Max Rear Camera Lenses and Bezels
iPhone 12 Pro Max Rear Camera Lenses and Bezels Afbeelding
Product
$12.99
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
It’s not something you’ll want to do if you don’t need to. It’s a very delicate procedure. You’ll want to heat up the adhesive of the broken bezel enough so you can carefully remove all the broken glass and adhesive. Be very wary not to scratch the camera lens during glass removal. If you’re worried about scratching the camera lens, you can remove it prior to chipping the glass. Clean it up a little more with alcohol. Once the surface is clean, putting the new bezel on is pretty straight forward.
Was dit antwoord nuttig?
7 opmerkingen:
Does this mean the bezel is externally replaceable; it does not require disassembly of the phone, only removal of the bezel directly?
door
Yeah. You don’t have to take anything apart. It’s pretty much a piece of glass that’s glued to the outside of the phone. If you want to be extra careful and take the cameras out, you’ll need to open up the phone. In some cases, it’s easier to take the cameras out and push the bezel out from the inside. But from your picture, it looks like you’ll have to just pick at the outside.
door
Thank you. But this isn't quite the question i was asking. I am talking about the metal bezel surrounding the glass. I have had the glass replaced already but the selling of a replacement bezel indicates that the bezel is itself replacable.
door
Colin, you are describing how to replace the lens. The bezel is the part that holds the lens. I am trying to figure out how to do this as well.
door
@cirofirvine did you have any luck with this?
door
2 commentaren meer tonen
Voeg je antwoord toe
Archie Campbell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 64
Altijd: 2,526
