Ga door naar hoofdinhoud
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274 Vragen Bekijk alle
New ifixit MacBook Pro Battery seems defective. Service required?
Hi All,
I bought a replacement battery for my 15” MacBook Pro Retina (Early 2013) last month. (Manufacturing date March 11, 2021)
I use iStat to monitor my system processes.
After only 16 cycles, it now says “Service Required” and only 76% Health. The battery only lasts an hour to an hour and a half with normal usage.
I’ve reset the SMC and the NVRAM already multiple times. I fully charged it, fully drained it multiple times.
Could I have gotten a defective battery? The current Capacity is reporting at 6552 mAh.
Thanks
*Edit* Added Coconut Report
**Edit* Fully charged battery now. Temp is 20 degrees lower, but life is still too short.
Is dit een goede vraag?
3 opmerkingen
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Voeg afbeeldingen toe aan een bestaande vraag
door
@danj Thanks. Added the Coconut report
door
The batteries temp seems high! What are you running when you took this and lets try placing the system under charge. Let it sit a good half hour to lower its temp and then take a fresh snap about 15 mins in so we can see how it's doing then.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I was only streaming some video when I took the snapshot. Fan's didn't come on, and the CPU temp is right around 140 F. ( I was trying to fully drain the battery before a full recharge. The Second shot is a fully charged battery and the only app running is Safari and Plex.
As a follow up, I submitted a ticket to iFixit today, and they're sending a replacement battery. Great customer service, just not looking forward to removing fresh adhesive .. ugh.
Was dit antwoord nuttig?
Voeg je antwoord toe
Andrew Harbison zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 56
