Ga door naar hoofdinhoud
Als deel van Google's derde generatie Pixel-telefoons, is de 3a het budget-gerichte model met dezelfde camera als Google's meest populaire modellen. Beschikbaar in spierwit, gewoon zwart, or paars-ig. Uitgebracht in Mei 2019.
70 Vragen Bekijk alle
Black screen - Does't open after replacing with new battery
Followed scrupulously the ifixit guide to replace the battery in my google pixel 3a, everything went very well. After the replace, before gluing the screen, I charged the battery in order to check if the replacement works, to my surprise the charging percentage didn’t appear on the screen, even after an hour or so. Tried to put the phone ON, nothing. I disassembled the phone, checking for a loose connection, everything is fine … When the phone is plugged in the charger, it gets warm, but doesn’t open, screen dead … Anybody as an idea of what is wrong? Thanks!
Paul
Is dit een goede vraag?
Score 3
2 opmerkingen:
This malfunction is common in some iPhone models, you must make a software for the mobile and it will return to work again But before that, make sure that you have installed the monitor cables correctly, taking into account the disconnection of the battery before installing the monitor.
door
Have the same issue, must've reseated everything over 12 times that I broke my proxy sensor cable eventually, the screen still won't power
door
Voeg een opmerking toe
2 Antwoorden
You must first reinstall the screen and make sure that all its filters are connected with the installation care and you disconnect the battery. If the attempt did not succeed, make a software for the mobile, as this is a common malfunction for some iPhone models.
Was dit antwoord nuttig?
3 opmerkingen:
Hi Ahmed, thanks for your answer, but what do you mean by “make a software” ?
Thanks
Paul
door
And also, I can't disconnect the battery while the Screen is connected ...
door
Reprogramming the device by a specialist
door
I have the same issue now. Did you find a solution in the end? Would love to know
Voeg je antwoord toe
Paul Abraham zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 429
