Tablet battery won't charge via Keyboard
Hi, I have a surface book 2 15", it's 2.5 years old, it's heavily used, the keyboard battery won't charge, stays at 0%. (the Tablet battery is fine)
I understand the keyboard Battery may have died of age, if that's the case, I'll replace it.
but my problem is that the Tablet battery won't charge if I plug the charger in the keyboard port, though the indicator light comes on, the percentage won't increase.
it'll charge only if I eject the Tablet and plug it in directly,
My question is, Is it because of the faulty keyboard Battery or charger or something wrong with the keyboard base?
will replacing the keyboard battery fix it?
Is dit een goede vraag?
9 opmerkingen
I have this issue as well the charger connector light flashes constantly, the tablet works fine because I charge separately only the keyboard that I have an issue with now? the did keyboard won't charge?
did you find any solution for that?
door Amrhar
I will try replacing the battery, here is a video mentioning the problem and fix .
https://www.youtube.com/watch?v=YxXyQWye...
door muhaiminul.h
did it solve the issue? I currently have the same problem. Have disassembled the base unit and successfully charged the previously fully discharged battery with an external battery charger. Windows still claims the battery is at 0% and charges neither Battery 1 (in the tablet) nor Battery two.
Suspiciously though, the attach/detach loop is gone now.
After having gone through the exercise of removing and re-installing the battery drivers, Windows now claims that there is no battery present.
The SB is seriously buggy in the battery charging department.
door HotelPapa100
Thanks for that - I was going to try the same thing, but now know that it's not worth the effort. So, also disconnecting the keyboard battery is useless, and I'm now thinking even replacing the battery isn't going to work. Not even going to risk buying a 60$ battery anymore.
door Bart de Boer
Has anyone found a solution to this? I have the exact same issue. The tablet won't charge unless plugged in directly.
door chris P
4 commentaren meer tonen
