Ga door naar hoofdinhoud
The HP Officejet 6500 is a color All-In-One printer. Released in 2003. Model number: CB815A#B1H.
52 Vragen Bekijk alle
small spring found at rear of printer after clearing a paper jam .
where did a small stainless steel spring 40mm long come from that I found at the rear of the printer base when I opened up the back to clear a paper jam.
It has an eyelet on one end and sort of a hook on the other.
could it be a spring for the tension to the top door that gives access to the glass scanner pane ?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
looks like to me you could be right or it is used for one end holding on to the printer and the other eyed end is put onto a gear somewhere a photo of the spring?
Was dit antwoord nuttig?
Voeg je antwoord toe
mark zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 52
