Adhesive to use to reassemble my Fitbit after battery replacement?
I am in the process of replacing the battery in my Fitbit Ionic but I don’t see adhesive listed under the parts or tools list, which is needed (and noted) for proper reassembly. Can someone recommend something similar to what Fitbit uses? I’m not going to use super glue in case I need to replace the screen battery again. Thank you.
Is dit een goede vraag?
