Ga door naar hoofdinhoud
Apple's top-of-the-line smartphone for 2020. Announced on October 13th and released November 13th, the iPhone 12 Pro Max sports a 6.7" OLED display, a triple rear camera system with LiDAR, and 5G connectivity. Successor to the iPhone 11 Pro Max.
97 Vragen Bekijk alle
Uncommon issue with tg0b error - Rebooting every 180 second
I’m having a very weird issue after replacing the dock connector for the original prs0 failure on the dock. The original battery isn’t detected and shows no percentage. This causes the phone to boot every 180 seconds. So I bought a new battery from a reputable company and it worked for around an hour. Then when I put the phone back together and rebooted the battery is back to the original batteries situation (no percentage and reboot every 180 seconds) I’m not sure what’s causing this to happen to the batteries. I don’t think it’s a board issue because a new battery solves it. I have bought a new battery for further testing.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
The *most likely* culprit from this scenario is slight damage to the battery connector data pins. Both battery data and charge port thermal sensor are required for this phone to not have a 3 minute reboot loop.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
flareX_72 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 183
