Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1482 Vragen Bekijk alle
How to fix white screen of death
I have found answers to this online saying to turn off the phone completely or just let it die I have done that more than once and nothing is working what should I do.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Did you try to put it in recovery mode or DFU mode and then connect it to iTunes or 3U tools?
Was dit antwoord nuttig?
Commentaar:
i cant connect it to itunes because i need the apple id password to update or do anything to it also i cant put in dfu or recovery mode because when i press the buttons nothing happens
door
3U Tools (freeware) can put it in DFU mode for you, you will lose all content in the iPhone also id passcode will be deleted
door
Voeg je antwoord toe
keith_themuscovyduck zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 23
