Ga door naar hoofdinhoud
Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
What is the correct BLADE SSD I should use?
Try to upgrade my 2012 iMac 27” with a blade SSD, but not sure if the following one I saw from eBay the correct part, can any one give an advise? Thanks.
SSD 128GB MacBook Pro Retina 13" & 15" 2012 2013 A1398 A1425 | 661-7008 661-7285
Is dit een goede vraag?
1 Opmerking
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Your iMac’s Blade SSD connector uses custom to Apple mSATA III (6.0 Gb/s) SSD. Apple offered five different sizes: 64, 128, 256, 512 & 768GB
Your other choice is using an OWC mSATA III (6.0Gb/s) SSD drive OWC offers four sizes 256, 500GB as well as 1.0 & 2.0TB
I strongly recommend you go with either of these choices. Sadly, your system does not support the faster PCIe/NVMe SSD’s and M.2 SSD’s won’t work as the physical interface is not the same.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks Dan! By the way, by looking at the link you gave, I did see part number 661-7008 mentioned there, thus, the one I saw from eBay should work for my iMac, right?
door
@lovecd - It should
door
Voeg je antwoord toe
Tom zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 68
