Ga door naar hoofdinhoud
Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
959 Vragen Bekijk alle
iPhone X slightly bent, Solder two layers together
How do I solder two layers back together when the top layer is slightly bent at the top?
Thanks in advance!
Is dit een goede vraag?
Commentaar:
@iammyron07 two layers of what? Has the screen separated or the logic board? Give us more detail
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If it is the front of the board that isn’t connecting I wouldn’t be too worried as they are all ground pads. If it is bent significantly you will need to solder the spacers back on and clamp it down while heating.
 I think there are about 8 spacers. You might have to get them from an unseparated IC board if you haven’t saved any from the other boards.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Myron. zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 18
