Ga door naar hoofdinhoud
Released by Samsung in March 2016. Model SM-G930.
20 Vragen Bekijk alle
phone won't turn on even when plugged in
awhile back the phone randomly glitched out when using it and i couldnt turn it back on, tried different button combinations and nothing worked, tried plugging it into the charger and nothing, waited a week or so to see if the battery would drain and try then but still nothing, no idea what to do now or if the phone is 100% dead, would like to atleast wipe the data off before sending it into a phone recycling place, any help here is welcomed, thanks in advanced!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi,
Do you have any testing equipment?
Multimeter and a usb amp meter would be very usefull.
If you simply want to wipe the phone before recycling it, then one thing you could do is extract the motherboard and drill a hole through it.
I hope this helps
Was dit antwoord nuttig?
Score 1
1 Opmerking:
dont have a usb amp meter and think ive got a mutlimeter here somewhere
door
Voeg je antwoord toe
Andrew Osborne zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 51
