Blown iMac 21.5 backlight circuit blown fuse?
I think I blew this fuse after putting in a new ssd and not realizing that the fan won’t run because the new ssd doesn’t have a sensor or something to make the fan run (yes I’m a total novice). Basically the computer ran fine and then boom it went to black. U can see images on the screen with a flashlight. So I think this fuse is part of the backlight circuit?
Is dit een goede vraag?
6 opmerkingen
What was the SSD you put in? The SSD shouldn't have done this..
door Dan
Dan, it was an OWC mercury electra. I don’t think that the ssd itself caused the problem. I was thinking that the fact that I replaced the ssd with a non factory one that did not have any sensor capable of telling the fan to come on was the problem. The computer ran fine but I guess the fan never came on and so it blew a fuse? Maybe maybe not? Not sure. Just a guess
door Larry Davis
@birdseye97 - OK, so you didn't handle the thermal issues switching out the HDD with a SSD as the SSD doesn't offer the needed thermal sensor for SMC services to wok properly.
Here's the needed sensor iMac Intel 21.5" and 27" (Late 2012-Early 2019) SSD Temperature Sensor
So yes, the blown Cap could be caused by overheating. The heat build up within the cap also looks like the logic board also has some damage with its traces. This will likely need a bit more than a simple desoldering and soldering in a new Cap.
I would recommend you find someone with good micro soldering skills and has a hot air station (re-work) as this really needs something a bit more powerful that a simple iron.
door Dan
Dan, thanks for the reply. I think that does it then. I t sounds like for me the best thing to do would be to move on. A hard lesson learned. But at least it was learned on an old computer. Oh well. Thanks again for the help.
door Larry Davis
@birdseye97 no way! Replace that 50 cent capacitor. Anybody with some decent soldering skills can do that. The component is large enough to not require any major micro soldering skills. Your traces do not damaged (it’s obviously a multilayered board and the traces for the caps are not even visible. Clean the soot of with a brush and some alcohol the desolder. You do not need a hot air rework station for this. Right now the most you have to lose is $10 max on parts etc. Don’t give up based on other peoples opinion. You came here to fixit so go for it. Nothing to lose but lots to gain.
door oldturkey03
1 commentaar meer tonen
