Ga door naar hoofdinhoud
Released September 22, 2017. Model A1863, A1905. Available as GSM or CDMA / 64, 128, or 256 GB / gold, silver, and space gray.
743 Vragen Bekijk alle
Home Button not working even after replacements
My wife dropped her iPhone 8 and there was no visible damage but the home button stopped working. I tired a soft reset, hard reset, factory reset, and firmware update. These did not work, so I replaced the home button with no results. So I tried replacing the entire screen along with a home button that I knew worked from use on another phone. Nothing is working and it is becoming extremely frustrating. Is there another part that I need to replace? Maybe the charing port assembly? (some call it the dock assembly?)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Firstly you cannot change a home button on the iPhone 8. It will not work at all. Try putting the original home button on your new screen if you haven’t already.
If this also fails you will need to take it to apple if you want your touch ID back or you could purchase a (Universal home button) it will work the same as an original one but without the touch ID.
Was dit antwoord nuttig?
Score 1
Commentaar:
Not at all? Even if I don't care to lose Touch ID? I replaced one on my 7 plus no problem. Just lost Touch ID, but the home function itself works on the 7 Plus.
door
Apple locks their home buttons to the motherboard so if your original home button doesn't work then touch ID is definitely out. In my experience it is a hit or miss with getting the home button to click again depending on the part you buy.
door
Voeg je antwoord toe
Michael Malambri zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 27
