Samsung BF641FST Oven - No LCD, No Heat or fan
The oven light still works when a selector knob is used, everything else is dead. Display is dead.
Any idea what to check? Thanks!
Is dit een goede vraag?
Hi,
You need to check if there is supply voltage at the TCO and then at the control board as per the troubleshooting flowchart
Be safety aware if you try this as you are testing for lethal AC voltage. If you don’t know how to do this safely then don’t do it!
Given that it is in a rental property this should be the responsibility of the landlord, not yours. Contact them or their agent about the problem.
Was dit antwoord nuttig?
I got the service manual, but the fault isn't covered in it. It's a UK 240VAC model.
I don't want to rip it apart without talking to the landlady first. I was hoping someone might recognise the symptoms and just know it's a PCB or fuse as pretty good guess, before I go digging.
Nothing preceeded the fault. It was fine last time it was used, and now it's not.
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 517
8 opmerkingen
Is the oven taken apart?
door Andrew S
@andrewsawesome Not yet! It belongs to the house we rent. I'm just trying to gauge whether it might be an easy/cheap fix, or need a professional, or replacement, before I contact the landlady.
door Glenn Mrosek
@Glenn Mrosek To me it sounds like a power supply or fuse issue, but it's hard to know without having the oven open.
door Andrew S
@andrewsawesome
The thing is, the light still works, but nothing else. I was just hoping it would promt an easy "I know what that is" response, before I approach the landlady with an informed guess on whether it's worth risking a repair, or to go for a replacement. It's not a cheap oven. :-/
door Glenn Mrosek
The TCO and elements all seem fine, though one of the plastic spade protectors is badly charred and melted. Gonna call the pro in for this.
Cheers!
door Glenn Mrosek
3 commentaren meer tonen
