iPhone 6s black screen but iTunes recognize it
hello.
I have bought this iPhone 6s today. it makes no sounds or vibrations and the screen is black but when i connect it to the pc it recognizes it and iTunes says “to allow connection answer on your iPhone”. I tried two different screens and batteries, i even swapped the motherboard with a fully working 6s but it still makes no sounds or vibrations and the screen is black. Is that a motherboard issue, and how can i fix it? thank you for your help :)
Is dit een goede vraag?
Can you put your IPhone into DFU mode by performing the following steps?
Turn off your iPhone and connect it to a computer using a Lightning to USB cable, and ensure iTunes is running.
Press and hold down the Sleep/Wake button on the handset for three seconds.
With the Sleep/Wake button still held down, press and hold the Home button, and keep holding both for 10 seconds.
Release the Sleep/Wake button, but keep holding the Home button for about 5 seconds.
If you performed the previous steps correctly and your phone's screen remained blank, a dialog prompt should appear on your computer saying "iTunes has detected an iPhone in recovery mode. You must restore this iPhone before it can be used with iTunes."
Press OK, then press “Restore iPhone".
door Andrew S
