Ga door naar hoofdinhoud
The larger version of Samsung's flagship phone. Released March 2018.
129 Vragen Bekijk alle
Why is my phone intermittently getting no signal?
So I have a samsung s9+ which has recently developed a problem connecting to 4G. I replaced the charging port and battery and then 2 days later it started getting problems connecting to 4G. It will work for an hour or 2 then all of a sudden won’t connect. Sometimes it loses signal all together and has a circle with a / through it and sometimes it says it has signal but doesn’t have the 4G symbol as normal. Does anyone know what I should be looking at to fix it?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @satnight101 ,
Check that the GSM antenna is securely fitted.
Here’s the Ifixit Samsung Galaxy S9 Plus Vervangen van de NFC-antenne en de oplaadspoel guide that may help. See Steps.10 &11.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Sam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 244
