Ga door naar hoofdinhoud
Released September 22, 2017. Model A1863, A1905. Available as GSM or CDMA / 64 or 256 GB / gold, silver, and space gray.
668 Vragen Bekijk alle
Camera App & Flash Issues!
Hey, I somewhat recently purchased a used iPhone 8. It has this issue where the camera app is just black, on both rear photos/selfies, and the flash doesn’t work (but I know the flash works in sync with the camera). However, sometimes I can get it to work (e.g. I reset the phone twice, got on a FaceTime call, or did an iTunes update and It suddenly works - both cameras and video, FaceTime, even Snapchat images). Sometimes it will stay working or sometimes it will stop (e.g. I set it up without an iCloud account once and added it and used it the next day - the camera had stopped working.
I am somewhat confused at what can be the culprit, as the cameras themselves do sometimes work, and when they do images are clear, audio is fine, and flash works perfectly, with no lag. Could it be a software thing (it is on the latest version - iOS 14.6 I think), or a motherboard IC chip issue. It hasn’t been repaired by me and True-Tone and stuff still work with some scratches and scuffs, so I don’t think the fault is a botched previous repair. I am thinking about bringing it into Apple, but that requires a trip to the City. Any ideas?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If you just purchased it I would firstly rule out a parts issue. Disconnect the front flex assembly and see if the rear camera starts working and vice versa with the rear camera.
If you take it to apple they will tell you it cannot be fixed and try and sell you another phone as apple stores do not fix iPhones beyond a replacement screen or battery.
Was dit antwoord nuttig?
Score 1
Commentaar:
Hey, I went to the store today as I had another device that got a warranty replacement. They did diagnostics and said everything appeared to work fine before both the cameras flashing a hardware issue - they weren’t working at the time the phone was tested. They quoted A$89 (so roughly $55 USD) for a rear camera replacement - only like AU$10-20 more than buying the part myself and doing it; quite reasonable actually (but debating it’s worth as it is just a 64gb 8 and I can do the repair myself and save a few bucks). They also said the front facing camera also flashed a hardware issue, and may or may not be resolved by a rear camera replacement - the guy couldn’t be certain. Hm… it really is strange!
door
Voeg je antwoord toe
TmG zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 15
