Ga door naar hoofdinhoud
Apple's line of iBook laptops was intended for the consumer and educational markets. The iBook line comprises of the iBook G3 Clamshell, G3 12", G3 14", G4 12", and G4 14".
1146 Vragen Bekijk alle
Does not Load OS, Tried disc Utility but does not Fix volume
Hey guys I have a iBook g4 with a OS 10.4 tiger and I tried starting it and all i would get would be a grey screen with the loading wheel you see after start up. I have used the hardware test disc and it said there was no problems. When I use the OS X 10.4 DVD and use the Disk Util. It says that a volume needs to be repaired but when I click disk repair it cannot fix it. What can I do. If I load in a fresh copy of the 10.4 OS will I lose all of my files on the hard Drive? Also if I have another mac avail. could I use my iBook as a slave and transfer my files to another mac? Please Help
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 1
Commentaar:
Gee, three correct answers in a row. Everybody gets a cookie.
door
Een opmerking toevoegen
iPhone Batterij Fix Kits
Slechts $29.99
Buy Now
Slechts $29.99
Buy Now
5 Antwoorden
Gekozen oplossing
If you just reinstall the system and don't erase the hard drive you will lose nothing. Chose the archive and install option. I would do what rj said to back up your files before installing. http://support.apple.com/kb/HT1545
Was dit antwoord nuttig?
Het nuttigste antwoord
Yes there is a way to transfer files. Its called target disk mode. I've included the URL to Apple on how to do the procedure. After you have transferred your files I would recommend formatting your drive and reinstalling your operating system. Good luck Ralph
http://support.apple.com/kb/HT1661
Score 1
Back up your files, erase the HD and install a fresh system and you'll know if the HD has a software or hardware issue.
Score 1
I ran the hardware test disk and it said that there were no problems so im assuming that it could just be a faulty hard drive
I have a similar problem ... the difference is that disk utilities said it repaired the disk ... but it is stil not booting .... Is there a way to ¨repair¨the operating system? The other problem is that my dvd has an older version of the leopard because the upgrade was made through internet. Can anybody help with a ¨How to¨ fix these?
Commentaar:
Please start a new question. Just copy this and paste it into a new one.
door
Voeg je antwoord toe
Mike zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 815
