Ga door naar hoofdinhoud
Repair information for impact drivers.
20 Vragen Bekijk alle
Trigger not triggering impact driver - how to diagnose/fix?
My erbauer impact driver started having intermittent problems where the trigger would t trigger the driver. This has gradually got worse, no it never works.
it’s not the battery, that works in the drill fine.
I’ve squirted contact cleaner in it, no joy.
you can see the problem in the video, you can see how the contact light flickers, it’s like there isn’t enough contact to get the thing going.
im not knowledgable enough to know what this means or how to diagnose it further.
Anyone any ideas?
Is dit een goede vraag?
Score 1
3 opmerkingen
Hi @tofuwarrior,
What is the model number of the drill?
door
Hi,
Thanks for answering.
I think it is ERI604IPD
The I might be 1.
It also says 15W45 00398
On it.
But I’m guessing the first one is the model.
Cheers,
Paul
door
Nu este asamblat bine acxul cu csneluri!
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Could be a bad switch "trigger" . I suggest you take it apart and use a multimeter to check the switch. You can of course never rule out a bad motor but for now I put my money on the switch.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Hi @tofuwarrior ,
I agree with @oldturkey03 about the trigger switch most probably being the problem.
I can't find your model listed here but it still may be worthwhile contacting them and asking if there are any parts available for the drill.
door
@jayeff @oldturkey03 , thanks very much for your advice and link to that supplier. I’ll find out how to check the switch using multimeter and see where we go from there ?
door
Voeg je antwoord toe
Paul zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 34
Altijd: 1,638
