Why is my MacBook not charging but was charging a moment ago?
Hi there ,
I have a MacBook Pro and I had plugged the charger in to charge it and I had unplugged the charger to plug in the Ethernet cable , As I have an L shaped power connector I needed to turn this around so that it would charge with the Ethernet cable inside the MacBook .
After I connected the power cable once again I saw nothing , no sign of charge from the charger or from the MacBook itself , I unplugged the power cable and Ethernet cable to plug in the power cable the way I had it before and this way doesn’t work either , I see no signs of wear as in the cable being damaged or frayed at all the charger looks perfectly fine, After trying to change the fuse for the power cable and resetting the SMC on the laptop still nothing , after attempting all the possible solutions without getting a new charger I think I may have tried , because of this my charge on my MacBook is now dead so the MacBook doesn’t turn on and the battery indicator on the side flashes with one bar to show me that the battery is out of charge .
I have also tried leaving the charger to “rest “ for 1 hour and then a whole night and still the charger doesn’t charge the MacBook at all . Please could someone help ? Thanks a lot
Is dit een goede vraag?
