Ga door naar hoofdinhoud
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
83 Vragen Bekijk alle
I want to convert the isight that comes with the display into an USB o
I have one isight from this screen and I want to use it in my Desktop computer as webcam converting it into a USB one. I've seen many people already done this with other modelos but mine has different wire colors
Update (06/22/2021)
This is my webcam connector https://drive.google.com/file/d/19FsGzWg...
Is dit een goede vraag?
Score 1
1 Opmerking
When i cut a usb cord there were only 2 wires?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@gerardit post some good pictures of what your camera connector looks like and the board where it plugs into. Cable colors are really not standardized yet and thus it can’t be taken for granted that it is connected different. Continue by checking the schematics and that will be your guide for that. The cable color will always correspond to their position on the connector. With this schematic you can connect it to a USB connector.
Voeg afbeeldingen toe aan een bestaande vraag
Update (06/27/2021)
@gerardit thank you for adding the image
Looks like
Pin 1 ==>Grey
Pin 2 ==> White
Pin 3 ==> Green
Pin 4 ==> Blue
Pin 5 ==> Black
White would be USB Data negative
Green would be USB Data positive
Blue would be USB Vcc 5V positive
Gray and Black would be ground.
Those colors actually already correspond with the standard USB cables with the exception Red on USB meets Blue on your camera.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
thank for your help it worked
door
Check out this guide Page 58 for the cameras wiring
5 opmerkingen:
@danj this must be one of your weakest answers ever. There is absolutely no reference to any of the wiring that is pertinent to this question. Maybe you should consider an edit to this.
door
@oldturkey03 - How so, a volt meter is all you need to ID the power and the other two are the USB data.
door
@danj not with the link to the manual you provided.
door
3. camera is the connection to the logic board.
Probing the header for voltage to remove the power feeds the USB data feeds are left (Green & White wires in your image)
The reason I didn't list the colors is Apple has used a few different suppliers which used different colors.
Granted I didn't hand it to them like you have, but I didn't want to mis-lead if the cable wires are different and I didn't have one to compare to be sure.
door
@danj oh I see. Just another outstanding explanation. Makes perfect sense to me :-)
door
Voeg je antwoord toe
Gerard zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 405
