Ga door naar hoofdinhoud
Handleidingen voor fornuizen en ovens op gas of elektriciteit.
102 Vragen Bekijk alle
Kenmore gas oven Bake Burner lights for 20 seconds then shuts off
I have a Kenmore Gas Oven model 790.36933900. The stove top burners work just fine, but the baking burner does not stay lit. The igniter glows and lights the burner, and the burner runs for 20 - 30 seconds and then turns off. After turning off the burner will re-light after about 20 seconds, then turn off again. The baking burner continues turning on and off every 20 seconds (or so) and the igniter remains glowing the entire time.
Also, the broil burner lights and stays lit, but the flame is very small compared to the baking flame.
I replaced the temperature sensor, but the problem persists.
Any help would be appreciated.
Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Here’s a video on possible fixes:
https://www.youtube.com/watch?v=BTChC_j4...
Was dit antwoord nuttig?
Score 1
Commentaar:
Thank you for the link to the possible fixes. The link appears to be for an electric oven, my oven is Gas. The burner lights for about 20 seconds, then shuts off, then re-lights / turns off about every 20 seconds.
Any other suggestions?
door
@abcdpiper
Don't know the answer but it may be worth it to buy the service data sheet and check if that helps.
Your oven is a rebadged Frigidaire and the part # for the service sheet is 318127055.
The service data sheet part number was found from this parts list for the oven
Once you have determined what the problem is and if a part needs replacing there are other suppliers online that may suit you better. Just search for 790.36933900 parts to get results
Voeg je antwoord toe
Chad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 28
