Ga door naar hoofdinhoud
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
409 Vragen Bekijk alle
xbox one s wont turn on and makes clicking sound then turns itself off
been doing this since last month, i try turning it on but everytime the xbox light lights up makes the starting sound, then after about a milisecond i hear a faint *click* and it shuts off right after, please help?
Is dit een goede vraag?
Score 2
1 Opmerking
I also have these problem
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
There are several things that may be causing this. It sounds like it may be a problem with something shorting or with the power supply. It is most likely the power supply. Here is the part you will need to fix it if it is in fact the power supply. Xbox One S Power Supply: Internal Replacement Part (ifixit.com)
Xbox One S Power Supply Afbeelding
Product
$29.99
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
It sounds like it would be the PSU.
door
@nytryder26 That is what I thought, too.
door
I have this same problem, baught and replaced the PSU, and it is still beeping/clicking, could it be the motherboard?
door
@Russel Hill Maybe try the Hard drive
door
Voeg je antwoord toe
eoinye10@gmail.com zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 38
Altijd: 368
