Ga door naar hoofdinhoud
Installed RRoD repair kit, now I have video problems with HD component
I installed RRoD kit, reflowed motherboard and repair seems to have worked but....when I hooked the Xbox up with component cables there is a vertical line down center of screen with a double display. Unit works with Standard definition cables and also with PC cable. Is this a problem with the cables or did I damage the graphics card?
Dave
Is dit een goede vraag?
Score -1
Commentaar:
What exactly do you mean by double display?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It sounds to me like that would be a case of bad cables. Do you have a friend that has the hd cables? If you do and you know they work on his console this would be a good way to test for the real problem.
Hope this helped,
Cody
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
daveboulanger zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 600
