Ga door naar hoofdinhoud
Model A1112 / 512 MB or 1 GB capacity
25 Vragen Bekijk alle
detected by computer but won't turn on after being unplugged
i found an old shuffle while digging around a drawer and wanted to try it out, it syncs and is detected by itunes (flashing orange light) but won’t even function by itself
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I had this exact issue with one I was given by a friend a few years back. The internal voltage of the battery has likely dropped to far and it has gone into “sleep” where it will refuse to accept a charge in order to prevent anything bad from happening (battery swelling/exploding). To fix this guy, you will probably need to get a new battery and install it. Not the easiest thing in the world, but it can be done. iFixit has a guide for removing the battery and logic board, from there would need to de-solder the old battery leads and solder in the new one, then re-assemble.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
turns out it just needed a good long charge, everything is good now!
door
Voeg je antwoord toe
Luke Timothy Davis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 21
