Ga door naar hoofdinhoud
Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
Joy Stick Barely Works. Connection is bad. Advice?
Howdy iFixit! I bought this PSP from the thrift store because it was only $30. (Expensive Thrift Stores here haha). It works really well in most cases except for the joy stick. It hardly responds to movement, and the curser/player when you're using it moves around on its own. If you apply pressure to the PSP in that area, it sort of starts working. From what I've researched, the contact from the joystick to the logic board has separated some, so it doesn't really contact the board that well. That's what I've diagnosed, too.
The problem is, however, that I don't really know how to fix it. Anyone else had this problem before? I think it all happens when the PSP is dropped. :P
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
TommyJames, this guide might help you out. Step 7 and on tells you what to do when the buttons are not working etc....
UPDATE
also, you might check this question. If cleaning it does not work you might have to replace the stick assembly. the part is available here and there are plenty of videos on on youtube.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
+ Very good accurate answer worthy of others referencing to it here on iFixit in the future.
door
Thank you so much oldturkey! I'm gonna try this probably over the weekend. With your help I'm sure to get the PSP working again! :)
door
I tried working on the PSP yesterday. It seemed to have been working really well at first, and then it just went back to not working. So, I think I've got to fidget with it for a while. Thanks so much for your advice!
door
Voeg je antwoord toe
TommyJames337 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 2,613
