Ga door naar hoofdinhoud
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
518 Vragen Bekijk alle
Can I use the screen assembly from a late 2013 MBP on a 2017 (15")?
My son spilled a water on my late 2013 MBP, and after a logic board cleaning and replacing the dc power adapter, I still get nothing when I plug it in.
I found a cheap 2017 15” with a broken screen, and wondered if I can swap out the display from my old one on to it. The compatibility lists I have been finding don’t really give me a solid answer.
Thanks in advance.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It’s a physically larger screen so I would imagine it wouldn’t work. Have you tried connecting the liquid damaged machine to an external monitor? I have the same one myself and I know they have an HDMI port.
Was dit antwoord nuttig?
Score 1
Commentaar:
Okay, that’s what I needed to know. As far as I could tell the late 2013 screen is only compatible up to mid 2014.[br]
[br]
It has no power, so nothing from the HDMI cable. The MagSafe doesn’t light up when plugged in. I replaced the DC adapter to no avail.
just now by dave
door
@daveybuoy then you might want to send it to Rossmann Repair. The owner Louis is a MacBook board repair specialist in NYC and he's got a youtube channel you can check out
door
Voeg je antwoord toe
dave zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 15
