Ga door naar hoofdinhoud
A2116 / 2019 / 3.6 GHz quad-core i3, 3.0 GHz 6-core i5, or 3.2 GHz 6-core i7 processor. Released March 19, 2019.
78 Vragen Bekijk alle
Machine is powering on but no display
During OS(Big Sur) updation suddenly light goes off. After few minutes we have tried to powering on the machine then we have found machine is powering on but no display. We have replaced the RAM and Hard drive but problem not resolve.if any one have any solution
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Ouch! I suspect you where a bit too quick!
During the OS and update processes your system will often appear off, in truth its just not able to display anything as the systems firmware (EFI) is being updated. So what you’ve now done is corrupted the process and pulled the chair from under the system to boot replacing things!
OK, so the firmware is in never-never land which we need to fix. At this point I would carefully put everything back together making sure the system does not look shop worn so Apple won’t object.
Now its time to visit an Apple Store or authorized service center with your system as being the best course.
So is there anything I can do my self? You’ll need to replace the logic board Apple has altered how EFI is setup on the newer systems and using a custom chip.
I have not been able to get the needed chip as well as the firmware. As such you can’t replace the chip with the needed firmware on these newer iMac’s. Apple has made it much harder to fix a simple issue like this. While still not an easy fix as you need to desolder a chip off the logic board and replace it at least it could be done.
Was dit antwoord nuttig?
Voeg je antwoord toe
Moinul Haque zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 88
