Ga door naar hoofdinhoud
Philips Wake-Up Light-wekker met gekleurde zonsopgangsimulatie, 5 natuurgeluiden en radio. Uitgebracht in april 2017. Modelnummer: HF3520/60.
device "clicking" quickly like proximity sensor feels something
Philips HF3520/01 Wake-Up Light - suddenly starts making never-ending quick “clicking“ sounds, speeding up.. This is normally sound of proximity (touch) sensor.. but there is nothing close to device, and it is clean…. It is unstoppable, only it stops if disconnected from power… After connecting it can work for hours correctly, but problem appears later again…
Is dit een goede vraag?
Score 2
1 Opmerking:
Same problem. Mine will work for weeks before this starts again, but the only fix is to unplug for at least a few minutes - The longer the better it seems. Works fine and I still love it otherwise.
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Mine has the very same issue, is there any known fix for this infinite phantom clicks? I really like my wakeup light for years now, it still looks like on day one.
Was dit antwoord nuttig?
2 opmerkingen:
I solved it. you just need to solder the wires well
door
So you think it's a broken solder joint? Is it enough to heat the PCB? I am highly unskilled when it comes to microelectronics.
door
Voeg je antwoord toe
guglmobil zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 85
Altijd: 879
