Ga door naar hoofdinhoud
Reparatiehandleidingen en -informatie voor de Nintento Switch Joy-Con controllers.
167 Vragen Bekijk alle
Joy-Con replacement kit did not fix drift
I found a similar question on this site, but the answers to it did not fix my issue. I bought iFixit’s Joy-Con repair kit and installed my new control stick part directly from its sealed bag. My control drifting persisted on the device. I updated the controllers per the first answer to the similar question and re-opened my device and reinstalled the control stick ensuring that its ribbon had no debris. This did not resolve my issue and the drift effect on my controller persists.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Have you tried calibrating the new control sticks? In Settings, Scroll Down to Controllers and Sensors, Calibrate Control Sticks, then follow the directions.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
This fixed my issue. Thanks!
door
I'm in the same situation, did you manage to find a solution?
My installation initially worked, but after just a few months both controllers are now experiencing so much drift they are entirely unusable to navigate even the Switch home menu.
I updated and calibrated both controllers.
Voeg je antwoord toe
Savvas Papadopoulos zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 19
Altijd: 198
