Ga door naar hoofdinhoud
1.83, 2, or 2.16 GHz Core Duo processor
349 Vragen Bekijk alle
No Wifi with closed lid
MacBook Pro 15" 2.16GHz Core Duo Model A1150
I mostly use my MBP in "closed-lid mode" and connected to an external monitor. The problem is the 802.11 signals cuts out when the lid is fully shut. Not completely, but it's either sporadic or "trickles", because a web page will take about 5 mins to load. Therefore, I have to open the lid a few inches to be able to use wifi. It sucks. Another possibly related problem is that the hinge is loose.
Bluetooth signal quality always sucked, but I've learned to live with it. I like my Mac, but shame on Apple for the expensive power supplies with connectors that break so easily.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
1 Antwoord
Gekozen oplossing
Replace your antennae cable: MacBook Pro 15" (Model A1150) Airport Antenna Cables
Was dit antwoord nuttig?
Score 5
Commentaar:
Thanks Mayer. Hopefully I can find one up here in Canada. Any idea how they fail? I've got the antenna module in my hand but I don't see any damage at all. The corner contact on the Airport board which appears to connect the shield to the MBP chassis looks quite oxidized though.
door
It worked! I ordered an antenna assembly from powerbookmedic.com for $0.95 + $2.86 S+H, installed it, and now my wifi works with the lid closed. Thank you so much, mayer. . . Now if only my bluetooth keyboard and mouse would work better together with the wifi :(
door
Dear Joe, That's great that you go tit running especially at that price. Now write another question and tell us about your keyboard and mouse ;-)
door
I celebrated too soon. The problem is back today.
door
Voeg je antwoord toe
Joe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 8
Altijd: 1,555
