Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Uitgebracht op 26 oktober 2018. Modellen A1984, A2105, A2105, A2106, A2108. Verkrijgbaar als GSM of CDMA / eSIM, nano-SIM of dual-SIM / 64, 128, of 256 GB / Zwart, Wit, Blauw, Geel, Koraal of Rood. (Uitgesproken "iPhone 10 R.")
239 Vragen Bekijk alle
I can't seem to get a new battery to charge in an iPhone XR.
Have installed two different new batteries in an Iphone XR. Plug the charger back in and it just sits in a boot loop. I see various current draw from the volt/amp meter that I have the USB plugged into so I know it’s trying something. But it’s just stuck in a boot loop. I left the new batteries to charge for multiple hours and nothing. If I plug the original battery in everything is fine. Any feedback would be great.
Is dit een goede vraag?
Commentaar:
where did you get the batteries from?
door
@hootonberg
One came from Mobilesentrix and the other was from MobileDefenders.
door
@itsd_btech ok good so we can eliminate those an a potential issue. Maybe try a DFU mode restore?
door
I tried that on both, nothing. I've have another battery I ordered from here. I'll see if that's the fix.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
If it works fine with the original battery but doesn't work with the aftermarket ones I would have to say the batteries you bought were probably not the best quality. I buy my batteries from fixez.com and I haven't had any problems with them. They even have the original to chip from texas instruments. It's what tells the battery health and percent of charge. It can have issues if you have a cheap battery.
Was dit antwoord nuttig?
Score 1
Commentaar:
Allan, thanks for the feedback. I'm tearing this phone down today (again) to install a battery I purchased from fixit. Also to see why the taptic engine isn't responding as well. Wish me luck and I'll keep y'all posted.
door
Battery works just fine.Problem now is my taptic engine and lower speaker don’t work. I’ve tried different taptic engines and different speakers and went all the way through to replace the charge port cable assembly. Interchanged the taptic and speaker on the new charge port assembly and nothing. Haptics are still enabled in the settings and all that jazz. Anyone have any ideas?
door
Well everyone, the new battery I ordered from ifixit worked just fine. So that fixed that problem.
Cheers everyone for your help.
Voeg je antwoord toe
A.J. Roest zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 26
